issues with SD-Wan and Extreme X450e-48p Stack
‎12-11-2018 10:33 PM
Hi -
I have a X450e-48p Stack (eight switches) running 15.3.5.2 patch1-19. Having issues with SD-Wan devices. SD-Wan engineers are seeing lots of ARP requests coming from Stack flooding the SD-Wan.
I found this article: https://extremeportal.force.com/ExtrArticleDetail?an=000089782
I have tried adding ‘configure iparp vr VR-Default max_pending_entries 256’ twice. Saved twice. Doesn't take. Can I not add that to a stack? The only iparp configuration is: 'configure iparp vr VR-Default max_entries 4096'
Is there any reason not to do this: https://extremeportal.force.com/ExtrArticleDetail?an=000082722
'disable flooding unicast ports all'
What is the best way to slow down ARP requests coming from Stack?
Thanks for any help.
‎12-11-2018 11:13 PM
OK. The article states to reduce from the default 256 to somewhere in the range of 50-150. This is going to vary from network-to-network and we can't really make a recommendation for a proper value because we aren't familiar with your installation scenario.
Regarding disabling unicast flooding, it may make more sense to rate-limit instead:
https://extremeportal.force.com/ExtrArticleDetail?an=000082704
I'm not sure how that will impact your goal.
Brad
‎12-11-2018 10:58 PM
so is:
configure iparp vr VR-Mgmt max_pending_entries 256
configure neighbor-discovery vr VR-Default max_pending_entries 1024
configure neighbor-discovery vr VR-Mgmt max_pending_entries 1024
Thanks
‎12-11-2018 10:52 PM
256 may be the default setting. If you run the command "show config detail | include max_pending_entries" does it have 256 as the setting in there?
Thanks
Brad
