Kill a specific process
Anonymous
Not applicable
Hi There,
Wondering if its is possible to kill a specific process based on ID. I ask as currently experiencing this issue:
code:
AP870-1.2 # show tech-support
Another session is already collecting system information
AP870-1.3 # show session
CLI
# Login Time User Type Auth Auth Location
*132 Wed Aug 14 18:14:59 2019 XMCac .. ssh2 local dis xxx.227.102.250
When I do a top I see this entry:
code:
 PID PPID USER   STAT  RSS %MEM CPU %CPU COMMAND
9253 2578 root S 11188 0.1 3 0.0 /exos/bin/expy -m showtech -- -u 1 -c show tech-support all detail
Wondering, do I perhaps just restart this process name:
code:
Process Name   Version Restart  State       Start Time    Group
techSupport 1.0.0.0 0 Ready Sat Jul 27 05:25:33 2019 EXOS
or is there a way to kill the process by process ID?
Version: 22.5.1.7
Switch: X870-96x-8c
Many thanks in advance
1 ACCEPTED SOLUTION
BradP
There is a way through debug mode, GTAC should be able to sort it out for you. Keep in mind that the process may reboot the switch, depending on the stability of the process.
6 REPLIES 6
Anonymous
Not applicable
Ah, Ok, I'll give them a call. Thanks
BradP
