lacp in x460-24t
lacp in x460-24t
sumeet
hi ,
i am using X460-24t extreme switch.
here is my setup
mydevice with two links configured in lacp mode --- extreme switch port 3
extreme switch port4
I have set vlan 3001 on port 3 as tagged with ip 172.16.254.1 . I run ping to it from my device with ip 172.16.254.2 .
I want to set lacp on port 3(master) and 4.
so , I ran
# enable sharing 3 grouping 3,4 algorithm address-based lacp
Question 1) had I used #enable sharing 3 grouping 3,4 lacp , what would be the difference ?
Question 2) Any specific command to see port sharing status ?
10 REPLIES 10
Erik_Auerswald
Contributor II
Hello Sumeet,
you are right that you configure the master port (VLAN, etc.) only, those settings are applied to all ports in the port sharing (rather to a logical port consisting of some physical ports).
If you disconnect and reconnect individual ports in a sharing, some packets may be lost, but a ping should resume.
Both LACP partner devices are configured the same, LACP does not use a master/slave configuration.
Br,
Erik
sumeet
got it .
Please correct me if I am wrong .
This is what I understand of LACP.
As told above
I think switch copies vlan setting of LACP master to other members of group.
Say my device has two ports named 3 and 4 connected to port 3 and 4 of extreme switch such that 3 is master and port 4 cable is unplugged.
Currently my device is pinging through 3.
Now I connect port 4 to 4 of device and then remove cable from port 3 .
The ping should not stop.
BTW is there any master slave concept like my device should be configured as LACP slave ?
Kawawa
Erik_Auerswald
Contributor II
You can use "show lacp lag detail" do look at the LACP status:
show lacp lag 3 detailBr,
Erik
Balaji_Kumar_Na
Q1: if you didn't use any address-based option (or) "address-based lacp" without specifying any algorithm like L3, L3_L4 and custom then default L2 algorithm will get set. So both CLI would result in no difference.
Q2: "show port sharing" command you can check the "Aggregator member" status
