im having a virtual lab, where i try to practice MLAG, the topology is as in the diagram
![a243e1b547394e11b8769eb43720b72b_RackMultipart20181014-105535-g6gk99-2018-10-14_17_57_47-EVE___Topology_inline.png a243e1b547394e11b8769eb43720b72b_RackMultipart20181014-105535-g6gk99-2018-10-14_17_57_47-EVE___Topology_inline.png](/t5/image/serverpage/image-id/5472iABF049326E63CF19/image-size/large?v=v2&px=999)
now i have a problem and some questions regarding MLAGmy problem that MLAG doesnt come up,
i have followed the following on both EXOS1 and EXOS2 switches
EXOS1
configure vlan default delete ports all
configure vr VR-Default delete ports 1-7
configure vr VR-Default add ports 1-7
configure vlan default delete ports 1-7
create vlan "ISC-VLAN"
configure vlan ISC-VLAN tag 10
create vlan "VLAN20"
configure vlan VLAN20 tag 20
enable sharing 3 grouping 3-4 algorithm roundRobin-based lacp
configure vlan ISC-VLAN add ports 3 tagged
configure vlan VLAN20 add ports 3 tagged
configure vlan ISC-VLAN ipaddress 1.1.1.1 255.255.255.252
configure vlan VLAN20 ipaddress 10.1.20.2 255.255.255.0
enable ipforwarding vlan VLAN20
create mlag peer "core"
configure mlag peer "core" ipaddress 1.1.1.2 vr VR-Default
EXOS2
configure vlan ISC-VLAN ipaddress 1.1.1.2 255.255.255.252
configure vlan VLAN20 ipaddress 10.1.20.3 255.255.255.0
configure mlag peer "core" ipaddress 1.1.1.1 vr VR-Default
Where's the output of show mlag peer on EXOS1
* EXOS01.131 # show mlag peer
Multi-switch Link Aggregation Peers:
MLAG Peer : core
VLAN : ISC-VLAN Virtual Router : VR-Default
Local IP Address : 1.1.1.1 Peer IP Address : 1.1.1.2
MLAG ports : 0 Tx-Interval : 1000 ms
Checkpoint Status : Down Peer Tx-Interval : 0 ms
Rx-Hellos : 0 Tx-Hellos : 120768
Rx-Checkpoint Msgs: 0 Tx-Checkpoint Msgs: 0
Rx-Hello Errors : 0 Tx-Hello Errors : 863
Hello Timeouts : 0 Checkpoint Errors : 0
Up Time : N/A Peer Conn.Failures: 0
Local MAC : 50:00:00:03:00:00 Peer MAC : None
Config'd LACP MAC : None Current LACP MAC : 50:00:00:03:00:00
Authentication : None
Alternate path information: None
and from EXOS2
EXOS02.42 # show mlag peer
MLAG Peer : core
Local IP Address : 1.1.1.2 Peer IP Address : 1.1.1.1
Rx-Hellos : 0 Tx-Hellos : 118591
Rx-Hello Errors : 0 Tx-Hello Errors : 1253
Local MAC : 50:00:00:04:00:00 Peer MAC : None
Config'd LACP MAC : None Current LACP MAC : 50:00:00:04:00:00
Alternate path information: Nonejudging from the output i think that the Hello is not happening between the peers.
can someone advice what am I doing wrong.
also
do we need to tag all VLANs (in this case VLAN 20 ) on ISC Ports? if not, how would the failover happen.
Thanks
Sulaiman
