Multi Devices Authentication
Mrxlazuardin
New Contributor III
Is Summit and/or BlackDiamond support multi devices authentication on single port? I mean that authentication status and policy will be applied exclusively per device, so a device may be authenticated whether the others may be not even they are connected to the same port. I find that way on Brocade (Foundry) device which is MAC address based authentication but I'm no sure Extreme net login has same behavior.
Best regards,
12 REPLIES 12
Hi Daniel,
Where can I find the official documentation of 1024 MAC address per switch limitation? As I know on datasheet, BlackDiamond support at least 8K MAC address on FDB per interface module and Summit X440 support 16K.
Best regards,
Mrxlazuardin
New Contributor III
Hi Daniel,
Is there any limitation should be concerned on implementation of this feature (ex. maximum MAC per port/vlan)?
Best regards,
dflouret
Mrxlazuardin,
In Network login, a supplicant gets identified as being learned on a specific VLAN and Port combination (we call this a virtual port). Each virtual port can hold one or more supplicants, each one of which has its own state.
With network login MAC-based operation, every authenticated client has an additional FDB flag that
indicates a translation MAC address. To view network login-related FDB entries, use the following command:
show fdb netlogin [all | mac-based-vlans]
The following is sample output from the show fdb netlogin mac-based-vlans command:
Mac Vlan Age Use Flags Port List
00:04:96:10:51:80 VLONE(0021) 0086 0000 n m v 1:11
00:04:96:10:51:81 VLTWO(0051) 0100 0000 n m v 1:11
00:04:96:10:51:91 VLTWO(0051) 0100 0000 n m v 1:11
Flags : d - Dynamic, s - Static, p - Permanent, n - NetLogin, m - MAC,
i - IP, x - IPX, l - lockdown MAC, M - Mirror, B - Egress Blackhole,
b - Ingress Blackhole, v - NetLogin MAC-Based VLAN.
The flags associated with network login include:
ā€¢ vā€”Indicates the FDB entry was added because the port is part of a MAC-based virtual port/VLAN
combination.
ā€¢ nā€”Indicates the FDB entry was added by network login.
Mrxlazuardin
New Contributor III
Hi Daniel,
I'm confused with your and Bill statement if comparing with following statement from Mutiple Supplicant Support of ExtremeXOS 15.7 User Guide (page 798).
"A port's authentication state is the logical ā€œORā€ of the individual MAC's authentication states. In other words, a port is authenticated if any of its connected clients is authenticated."
Can you explain more about the different?
Best regards,
dflouret
Mrxlazuardin,
If you have multiple supplicants in a port that use untagged traffic, you have to enable MAC-Based VLANs in that port (see EXOS User Guide, page 831).
In that case, each individual MAC is assigned to a VLAN when authenticated in the port. Traffic from unauthenticated MACs is not forwarded.
