08-04-2021 09:40 AM
We have several EXOS switches connected through the MPLS network. Sometimes link flapping in other locations causes MPLS problems in a completely different location. The only solution to the problem is to restart the switch. Errors that appear on the switch:
7/09/2021 07:54:49.93 <Erro:Kern.MPLS.Error> MPLS: bcm_mpls_port_add failed for unit = 0 vpn = 0x702f, port = 0xc000001 vp = 0x180014ed, rv = -13 (Invalid identifier)
07/09/2021 07:54:49.74 <Erro:Kern.MPLS.Error> MPLS: bcm_mpls_port_add failed for unit = 0 vpn = 0x702c, port = 0xc000001 vp = 0x180014ec, rv = -13 (Invalid identifier)
07/09/2021 07:54:49.69 <Erro:Kern.MPLS.Error> extreme_custom_mpls_pw_trunk_port_update1: MPLS ECMP NH vp : 0x14eb l3intf = 0x8c0 map entry not found in btree rv = -7 (Entry not found)
07/09/2021 07:54:49.69 <Erro:Kern.Error>
07/09/2021 07:54:49.69 <Erro:Kern.MPLS.Error> MPLS: bcm_mpls_port_add failed for unit = 0 vpn = 0x7067, port = 0xc000001 vp = 0x180014eb, rv = -13 (Invalid identifier)
07/09/2021 07:54:49.50 <Erro:Kern.Error>
07/09/2021 07:54:49.50 <Erro:Kern.MPLS.Error> MPLS gport resolve failed for unit = 0 vpn = 0x7006, port = 0xffffffff vp = 0x180014a6, rv = -7 (Entry not found)
07/09/2021 07:54:49.50 <Erro:Kern.MPLS.Error> extreme_custom_mpls_pw_trunk_port_update1: MPLS ECMP NH vp : 0x14a6 l3intf = 0x8c7 map entry not found in btree rv = -7 (Entry not found)
07/09/2021 07:54:49.50 <Erro:Kern.MPLS.Error> extreme_custom_mpls_pw_trunk_port_update1: MPLS ECMP NH vp : 0x14ea l3intf = 0x8c0 map entry not found in btree rv = -7 (Entry not found)
07/09/2021 07:54:49.50 <Erro:Kern.MPLS.Error> MPLS: bcm_mpls_port_add failed for unit = 0 vpn = 0x7056, port = 0xc000001 vp = 0x180014ea, rv = -13 (Invalid identifier)
07/09/2021 07:54:49.50 <Erro:Kern.MPLS.Error> extreme_custom_mpls_pw_trunk_port_update1: MPLS ECMP NH vp : 0x14e9 l3intf = 0x8c0 map entry not found in btree rv = -7 (Entry not found)
07/09/2021 07:54:49.50 <Erro:Kern.MPLS.Error> MPLS: bcm_mpls_port_add failed for unit = 0 vpn = 0x7052, port = 0xc000001 vp = 0x180014e9, rv = -13 (Invalid identifier)
07/09/2021 07:54:48.80 <Erro:Kern.MPLS.Error> MPLS: bcm_mpls_port_add failed for unit = 0 vpn = 0x701c, port = 0xc000001 vp = 0x180014e0, rv = -13 (Invalid identifier)
07/09/2021 07:54:48.74 <Erro:Kern.MPLS.Error> MPLS gport resolve failed for unit = 0 vpn = 0x7067, port = 0xffffffff vp = 0x1800149c, rv = -7 (Entry not found)
07/09/2021 07:54:48.74 <Erro:Kern.MPLS.Error> extreme_custom_mpls_pw_trunk_port_update1: MPLS ECMP NH vp : 0x149c l3intf = 0x8c0 map entry not found in btree rv = -7 (Entry not found)
07/09/2021 07:54:48.61 <Erro:Kern.MPLS.Error> MPLS bcm_mpls_port_del failed for unit = 0 vpn = 0x702c, vp = 0x1800149e rv = -7 (Entry not found)
07/09/2021 07:54:48.61 <Erro:Kern.MPLS.Error> extreme_custom_mpls_l2vpn_port_del: MPLS port delete: vp: 0x149e l3Intf = 0x8c1 map entry not found in btree rv = -7 (Entry not found)
07/09/2021 07:54:48.61 <Erro:Kern.MPLS.Error> extreme_mpls_del_vp_nh_xref: MPLS ECMP NH vp : 0x149e l3intf = 0x8c1 map entry not found in btree rv = -7 (Entry not found)
07/09/2021 07:54:48.61 <Erro:Kern.Error>
07/09/2021 07:54:48.61 <Erro:Kern.MPLS.Error> MPLS gport resolve failed for unit = 0 vpn = 0x702c, port = 0xffffffff vp = 0x1800149e, rv = -7 (Entry not found)
07/09/2021 07:54:48.61 <Erro:Kern.MPLS.Error> extreme_custom_mpls_pw_trunk_port_update1: MPLS ECMP NH vp : 0x149e l3intf = 0x8c1 map entry not found in btree rv = -7 (Entry not found)
07/09/2021 07:54:48.29 <Erro:Kern.MPLS.Error> MPLS: bcm_mpls_port_add failed for unit = 0 vpn = 0x7027, port = 0xc000001 vp = 0x180014de, rv = -13 (Invalid identifier)
07/09/2021 07:54:48.23 <Erro:Kern.MPLS.Error> MPLS gport resolve failed for unit = 0 vpn = 0x7066, port = 0xffffffff vp = 0x180014b4, rv = -7 (Entry not found)
07/09/2021 07:54:48.23 <Erro:Kern.MPLS.Error> extreme_custom_mpls_pw_trunk_port_update1: MPLS ECMP NH vp : 0x14b4 l3intf = 0x8d5 map entry not found in btree rv = -7 (Entry not found)
07/09/2021 07:54:48.10 <Erro:Kern.MPLS.Error> extreme_custom_mpls_pw_trunk_port_update1: MPLS ECMP NH vp : 0x14dc l3intf = 0x8e3 map entry not found in btree rv = -7 (Entry not found)
07/09/2021 07:54:48.10 <Erro:Kern.Error>
07/09/2021 07:54:48.10 <Erro:Kern.MPLS.Error> MPLS: bcm_mpls_port_add failed for unit = 0 vpn = 0x707c, port = 0xc000001 vp = 0x180014dc, rv = -13 (Invalid identifier)
07/09/2021 07:54:47.91 <Erro:Kern.MPLS.Error> MPLS: bcm_mpls_port_add failed for unit = 0 vpn = 0x707c, port = 0xc000001 vp = 0x180014d9, rv = -13 (Invalid identifier)
09-04-2023 05:38 AM
We too have experienced a similar situation. Was this problem successfully fixed? If so, in which firmware version?
08-18-2021 05:08 PM
we use 16.2.5.4 patch 29, we have G1 hardware version
08-13-2021 02:55 PM
That looks like apossible programming issue. What version of firmware are you on?
Thanks,
Chris Thompson
