Problem with switch x670-G2
pbrzostowski
Hi
What are thinking about this log infomation. I'am not found any information on the web. My action: I'am add vpls peer, vlan and save config and he crushed 😞 Soft 31.4.1.5. Switch shutdown all port and no ping. No access via console rs-232 because switch is installed 63km away. This log below when switch i restarted by power off and on. Something wrong with this device ???
12/20/2021 21:16:30.17 <Warn:exsshd.KeyAuthFail> Key authentication failed for user - from 10.1.1.102. Key invalid/not configured to the user.
12/20/2021 21:16:30.17 <Warn:exsshd.KeyAuthFail> Key authentication failed for user ------- from 10.1.1.102. Key invalid/not configured to the user.
12/20/2021 21:18:26.15 <Crit:Kern.Alert> CPU 1: soft watchdog expiration warning at ffffffff8016a1c0 (__r4k_wait+0x20/0x40) for 2 seconds, process swapper/1 (0)
12/20/2021 21:18:26.35 <Crit:Kern.Alert> CPU 3: soft watchdog expiration warning at ffffffff8016a1c0 (__r4k_wait+0x20/0x40) for 2 seconds, process swapper/3 (0)
12/21/2021 09:35:01.34 <Noti:EPM.wd_warm_reset> Changing to watchdog warm reset mode
12/21/2021 09:35:01.45 <Warn:EPM.UnexpctRebootDtect> Booting after System Failure.
12/21/2021 09:35:01.46 <Noti:EPM.start> EPM Started
12/21/2021 09:35:01.71 <Noti:NM.StrtProc> The Node Manager (NM) has started processing.
12/21/2021 09:35:03.11 <Noti:DM.Notice> DM started
12/21/2021 09:35:04.25 <Noti:log.serverStarted> The Event Management System logging server has started.
12/21/2021 09:35:06.10 <Noti:licMgr.EnblFeatLcns> Enabled the Core license product for the Core feature(s).
12/21/2021 09:35:06.10 <Noti:licMgr.EnblFeatLcns> Enabled the MPLS license product for the MPLS feature(s).
12/21/2021 09:35:06.13 <Noti:licMgr.Notice> Unknown generic capacity license = 1, name=TCAM Capacity, slot=1
12/21/2021 09:35:06.13 <Noti:licMgr.Notice> Failed to add legacy capacity license.
12/21/2021 09:35:06.13 <Noti:licMgr.Notice> Unknown generic capacity license = 2, name=Port Capacity, slot=1
12/21/2021 09:35:09.24 <Info:HAL.Sys.Info> Starting hal initialization ....
12/21/2021 09:35:34.46 <Info:HAL.Card.Info> Bluetooth capability is not supported
12/21/2021 09:35:34.47 <Noti:HAL.Sys.Notice> Module in fan slot 1 is inserted
12/21/2021 09:35:34.69 <Noti:HAL.Sys.Notice> Module in fan slot 2 is inserted
12/21/2021 09:35:34.84 <Noti:HAL.Sys.Notice> Module in fan slot 3 is inserted
12/21/2021 09:35:34.99 <Info:HAL.Sys.Info> Internal PSU-1 is present.
12/21/2021 09:35:34.99 <Info:HAL.Sys.Info> Internal PSU-1 is powered off.
12/21/2021 09:35:34.99 <Info:HAL.Sys.Info> Internal PSU-2 is present.
12/21/2021 09:35:34.99 <Info:HAL.Sys.Info> Internal PSU-2 is powered off.
12/21/2021 09:35:35.23 <Info:HAL.Sys.Info> Hal initialization done.
12/21/2021 09:35:35.26 <Info:nl.init> Network Login framework has been initialized
12/21/2021 09:35:35.29 <Noti:DM.Notice> Node State[1] = INIT
12/21/2021 09:35:35.31 <Info:SNMP.Subagent.InitDone> snmpSubagent initialization complete
12/21/2021 09:35:35.74 <Info:telnetd.info> **** telnetd started *****
12/21/2021 09:35:35.83 <Info:DOSProt.Init> DOS protect application started successfully
12/21/2021 09:35:36.74 <Info:DM.Info> Node INIT DONE ....
12/21/2021 09:35:36.74 <Noti:DM.Notice> Node State[2] = STANDBY
12/21/2021 09:35:36.85 <Noti:SNMP.Subagent.MstrRestrt> snmpMaster process has been restarted.
12/21/2021 09:35:37.49 <Info:tftpd.info> **** tftpd started *****
12/21/2021 09:35:38.23 <Info:HAL.Sys.Info> Internal PSU-1 is disconnected.
12/21/2021 09:35:38.23 <Info:HAL.Sys.Info> Internal PSU-2 is disconnected.
12/21/2021 09:35:40.24 <Noti:DM.Notice> Node State[3] = OPERATIONAL
12/21/2021 09:35:40.24 <Crit:cm.file.openErr> Failed to open file "primary": Last save failed to complete before switch rebooted, reverting to previous save state
12/21/2021 09:35:40.61 <Info:EPM.wdg_enable> Watchdog enabled
12/21/2021 09:35:58.16 <Noti:EPM.system_stable> System is stable. Change to warm reset mode
12/21/2021 09:36:00.93 <Info:telnetd.info> telnetd listening on port 23
12/21/2021 09:36:01.98 <Info:AAA.LogSsh> Msg from Master : Loaded Private Key of size 1675 from System
12/21/2021 09:36:02.13 <Info:AAA.LogSsh> Msg from Master : Generating RSA-2048 public key
12/21/2021 09:36:02.23 <Info:AAA.LogSsh> Msg from Master : Existing host key with fingerprint SHA256:--------------------------------------- loaded successfully
12/21/2021 09:36:02.52 <Info:SNMP.Master.InitDone> snmpMaster initialization complete
12/21/2021 09:36:03.44 <Warn:log.NVRAMFull> NVRAM is full, old messages are overwritten.
12/21/2021 09:36:07.95 <Info:HAL.Card.Info> Switch is operational
1 REPLY 1
CThompsonEXOS
I would open a case with GTAC regarding this.
Thanks,
Chris Thompson
