Problems with connectivity on VLAN mgmt
‎08-23-2016 12:16 PM
Hello,i have an extreme switch x440-g2.
i try to put an ip in the mgmt vlan, but after doing that, switch does not ping.
After i enabled dhcp, and i have communications by the default vlan.
I need to set an specific ip for Mgmt, and i cant do that. Can someone help me please.
10 REPLIES 10
‎08-23-2016 03:28 PM
Well, it seems i´ve overcome this step.
Now i have a static ip on deefault vlan as desired.
I´ll proceed with the rest of configurations.
Thank you all for the support.
‎08-23-2016 12:29 PM
Thank you very much.
May i just ask one more thing.
howcome i still have this message in GUI of the switch
Error while loafing rpifconf rip configuration ignored for vlan default-no ip address found.
But i have an ip on the swithc, i can even connect to it.....
Hello, no configuration at all
When do you see that message appear? Do you have a rip configuration present on the switch?
