Problems with connectivity on VLAN mgmt
‎08-23-2016 12:16 PM
Hello,i have an extreme switch x440-g2.
i try to put an ip in the mgmt vlan, but after doing that, switch does not ping.
After i enabled dhcp, and i have communications by the default vlan.
I need to set an specific ip for Mgmt, and i cant do that. Can someone help me please.
10 REPLIES 10
‎08-23-2016 12:22 PM
Hello tunfas, I've updated the topic title to better fit the question you've asked. I hope that's okay.
That said, the mgmt vlan is special in that it ONLY works on the dedicated MGMT port on the front left side of the switch.
Check out these two articles to see if they help with your issue.
