save current config in a file in extreme switch
sumeet
we have summit X460-24t switch
usually I telnet to it and run
show config
log the contents of telnet session to a file
The problem is when screen fills up I get 'press space to continue or q to quit' , then I have to press space .
Is there a better way to get current config ?
Thanks.
26 REPLIES 26
Baskar
Hi Sumeet,
Execute the command "disable clipaging "
it's used to Disables pausing of the screen display when a show command output reaches the end of the page.
AndrƩ_Herkenrat
You can use the command:
save configuration as-script
Afterwards you can retrieve the file via tftp
Best
AndrƩ
