set fan speed for XOS
Arman
Hi guys, how could I set fan speed for XOS switches?
Thanks in advance.
9 REPLIES 9
Arman
Great, I wil use the release.
BrandonC
Hi Arman,
If the fan is running at very high speed, there is a known issue related to this. I don't have the CR number available right now, but it should be fixed in the latest patch of EXOS 15.5.3.4, which is the recommended version for the X430.
Arman
Hi Drew, is the Summit X430-24t
Drew_C
Valued Contributor III
Hi Arman,
The fan speed on newer products is tied to environmental temperature and in some models, tied to processor temperature. Older products have a "binary" fan.
Which model(s) are you curious about and we can at least give you some insight as to whether or not the fan speed is relative to temperature.
Bill_Stritzinge
You cannot manually control the fan speeds on any XOS switch, I guess if you get it hot enough you can make them go faster... ļ™‚
