set fan speed for XOS
‎03-18-2015 06:58 PM
Hi guys, how could I set fan speed for XOS switches?
Thanks in advance.
Thanks in advance.
9 REPLIES 9
‎03-18-2015 07:43 PM
Great, I wil use the release.
Hi Arman,
If the fan is running at very high speed, there is a known issue related to this. I don't have the CR number available right now, but it should be fixed in the latest patch of EXOS 15.5.3.4, which is the recommended version for the X430.
Hi Drew, is the Summit X430-24t
Hi Arman,
The fan speed on newer products is tied to environmental temperature and in some models, tied to processor temperature. Older products have a "binary" fan.
Which model(s) are you curious about and we can at least give you some insight as to whether or not the fan speed is relative to temperature.
‎03-18-2015 07:33 PM
You cannot manually control the fan speeds on any XOS switch, I guess if you get it hot enough you can make them go faster... 
