Hi folks!
I've tried to expand number of SFP ports in quite old one Alpine 3802 (45064) switch using second GM-16X3 card (45121) and it comes up with this fault:
System does not have enough power left to support card 2.
This unit is powered with 2 internal DC PSUs fed from >10A sources each.
ExtremeWare Error Decoder is not much useful:
1 Check the power supply. - done 2 If necessary, replace power supply units. - PSUs are embeded 3 If the problem persists, contact Technical Support. - unsupported unit
There's no
show powercommand in this unit.
Alpine3802:37 # show slot Slot 1 information: State: Operational HW Module Type: GM-16X3 Configured Type: GM-16X3 Gigabit ports available: Link Active: 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 Link Down: Slot 2 information: State: Powerdown HW Module Type: Empty Configured Type: GM-16X3 Slot 3 information: State: Empty HW Module Type: Empty Configured Type: Not configured Whenever I remove the card from the first slot - the second one comes up ok.
Any ideas? I'm stuck with this problem, as I need to keep this boy working.
Thanks,
Michal
