X670-G2 Upgrade path
CarlosRR
Hi Experts,
I have a new one X670-G2 running 800546-00-17 1911N-47285 Rev 17 BootROM: 1.0.2.1 IMG: 22.6.1.4.
There is any recommended upgrade path or could I upgrade straight to version summitX-30.5.1.15?
Thanks in advance,
BR\
Carlos.
15 REPLIES 15
CarlosRR
Brad,
Many thanks for your support!
Best regards,
Carlos
BradP
Hi Carlos,
That is correct. EXOS 22.7.1.2 Patch 1-21 is the current recommended stable version. If there is a certain feature that you must run in 30.5, then please run that version. But if there is none, we (in GTAC) recommend sticking with the normal recommended stable version.
Thanks!
Brad
CarlosRR
Brad,
Just the last one,  if I understood correctly, the recommendation is to run 22.7.1.2 Patch 1-21, not to upgrade to 22.7.1.2 Patch 1-21  and after 30.5, right?
BR\
Carlos
BradP
Hi Carlos,
The patch contains the standard image as well. No need to make any intermediary steps.
Regards
Brad
CarlosRR
Hi Brad,
I’ll follow the recommendation so, thank you!
Its necessary to upgrade first to 22.7.1.2 or I can go straight to 22.7.1.2 Patch 1-21?
Regards,
Carlos.
