lost operational code / firmware due to internal battery replacement ?
‎10-01-2014 08:29 PM
After some years of use we stop and clean C3G124-48 and also replace internal bateries after doing that never more the switch boot up to operational code.
We think the system lost the firmware due to replacement of this battery (is this possible??)
The system goes only to this line and stops.
Enterasys C3-Series Boot Code...
SDRAM Circuit Test of 255MB
100%
How is possible to load again the firmware to the unit on this status.
Thanks in Advance
100%
Thanks in Advance
28 REPLIES 28
‎10-04-2014 08:32 AM
yes, correct. I use for this cheap multimeter in current mode. https://www.homepower.com/sites/default/files/uploads/3_cheap-meter.jpg
So, you mean, connect the power and with a wire touch the box, and that spot 28 of the chip : E28F128J3A ??
It is safe for the electrical installation? I don´t care about the switch
hmm, probably try that empty space for chip E28F128J3A, spot 28.
you sent me same side just 90 rotated. would you please post other side of that board?
