Need to find OIDs for switches 3k, 4k, 5k and 7k series for CPU and memory
SaharYacout
New Contributor II
Is there a browser where I can search the OIDs i need for cpu, memory, interface usage for 3k, 4k, 5k and 7k series.
Thanks
Sahar
8 REPLIES 8
Markus_Nikulski
please note, that VSP have a different private MIB  tree (RapidCity) than ERS (Synoptics). They are only some little exception where VOSS have Synoptics C5000 MIB elements supported.
So for the CPU Memory you have to use different OIDs per VOS & ERS switch.
SaharYacout
New Contributor II
@Markus Nikulski I was actually searching for something that works for ERS and VSP stackable switches which only the synoptic Mibs worked with. RapidCity OIDs are not available on any of my 38 stacks.
Markus_Nikulski
please note, for all the current VOSS based switches you have to use this MIB tree to get access to the system resources. (RapidCity MIB)
rcKhiSlotPerfEntry  1.3.6.1.4.1.2272.1.85.10.1.1
Several example above are wrong, because they pointing to the Synoptics MIB!!!!
Here the details about CPU utilization
Name:    rcKhiSlotCpuCurrentUtil    => OID:    1.3.6.1.4.1.2272.1.85.10.1.1.2
Description:    Percentage CPU utilization under current
     operating conditions.
SaharYacout
New Contributor II
also this resource is amazing:
http://oidref.com/1.3.6.1.4.1.45.1.6.3.8.1.1
