Need to find OIDs for switches 3k, 4k, 5k and 7k series for CPU and memory
SaharYacout
New Contributor II
Is there a browser where I can search the OIDs i need for cpu, memory, interface usage for 3k, 4k, 5k and 7k series.
Thanks
Sahar
8 REPLIES 8
SaharYacout
New Contributor II
The below worked for all 3k,4k,5k and 7k switches, which I found to be awsome
https://extremeportal.force.com/ExtrArticleDetail?an=000082411
  • CPU Utilization
    s5ChasUtilTotalCPUUsage OBJECT-TYPE
    SYNTAX Gauge32 (0..100)
    MAX-ACCESS read-only
    STATUS current
    DESCRIPTION
    "This object returns the percentage of time the CPU has been
    busy since system initialization."
    ::= {s5ChasUtilEntry 4}
    OID .1.3.6.1.4.1.45.1.6.3.8.1.1.4
  • Memory
    s5ChasUtilMemoryAvailable OBJECT-TYPE
    STATUS current
    DESCRIPTION
    "This object returns the percentage of dynamic memory that
    is currently free. This is measured as a percentage of
    the memory the was available immediately after system
    initialization."
    ::= {s5ChasUtilEntry 9}
    OID .1.3.6.1.4.1.45.1.6.3.8.1.1.13
StephanH
Valued Contributor III
Hello Sahar,
it would be great if you could share the OIDs that work for you here. I think there are certainly colleagues who can also use them.
Regards Stephan
SaharYacout
New Contributor II
Thanks @StephanH I couldn’t use the oids on this article. @JoyceHarris Also that OID doesn’t work on any of my switches. However I contacted the support they supplied me with oids for CPU and memory.
I was wondering how that iMessage PC works, I am trying to poll data from my switches and what I am missing is a place or a tool that have some relevant OIDs. I want to monitor the packets lost too and the bandwidth on the interfaces
StephanH
Hello Sahar,
see here:
Regards Stephan
