AeroScout Location-based Solution ?
Shooter_Chiang
New Contributor II
Hi Everyone,
Extreme Wireless V2110 : V9.15
AP Model : AP3825i
I try to using an AeroScout Location-based Solution,setting as V9.15 User Guide,
but AeroScout Server can't find the AP device,does anyone using AeroScout Wifi Tag
with Extreme AP3825i or any model work before ?
Thanks
Regards,
Shooter
8 REPLIES 8
Raffi
By the way, we only do wds. Here ibss and wds refer to the way that the tag sends the l2 multicast frame. Kind of weird words to choose, makes me think of other 802.11 terminology.
OK. I have to wait next time for have Aeroscout Server Test Environment,
I will collect all information, thanks Raffi and Doug.
Doug
Yes, it will support it.
Doug Hyde
Sr. Director, Technical Support / Extreme Networks
I just wanna to know the AP3825i support AeroScout Location-based Solution ?
I don't know Aeroscout Server setting and version,because it's responsible for other partner.The Test Environment with Aeroscout Server is not anymore.
If AP3825i AeroScout Location-based Solution can work,and there is another Test Environment , i will collect more information for troubleshooting.
Thanks for your information,
