AP250 wifi0 radio stuck at 5dB
w1f1n00b
Contributor II
Despite all efforts wifi0 won't change from 5dB. Nothing seems of note in the logs.
things tried
  • manual setting change in GUI
  • radio power change in CLI
  • reset AP to default
  • delete and re-onboard
  • firmware change
Could this just be bad hardware?
Any help appreciated
1 ACCEPTED SOLUTION
w1f1n00b
Contributor II
After checking on the AP this morning, it appears that the delete-re-onboard solved the issue. I'm now seeing both radios up at 10dB, and I'm able to apply manual power changes.
Weird.
1 REPLY 1
w1f1n00b
Contributor II
Weird.
