ā12-12-2022 03:35 PM
Hey Everyone,
Is there a way I can check what is causing the delay in connecting to the wireless network? I am using AP 230, devices that are taking time to connect are position ~10 meters from AP. I am using both 2.4 and 5Ghz radio.
Using it for over 1.5 years and problem only started few months back when I upgraded the firmware or while playing with AP template. I removed the template but the issue still persists.
| Model | OS Ver | wifi0 channel | wifi0 power | wifi1 channel | wifi1 power | mgmt vlan |
| AP230 | 10.5.2.0 | 1 | 20 | 40 | 17 | 1 |
Also, I will really appreciate if someone can point to an article that can help me configure it with optimal radio settings. I have 2 of these units, I was planning one can be 2.4 only other one can be 5GHz only
ā04-25-2023 02:42 PM
Here is an article to help with RF interference:
https://extremeportal.force.com/ExtrArticleDetail?an=000079422
Regards,
Benjamin Tam
Technical Support Engineer / Extreme Networks
Office 1-800-872-8440
ExtremeNetworks.com
Customer-Driven Networkingā¢
