Deployment of V2110 on VMWARE ESXi problem: Vlans
LeoP1
Contributor
We are working on a deployment of 2 new V2110 controllers on customer's ESXi 5 infrastructure, but even configuring with an old guide from the KB, we can't make the traffic of tagged VLANs to reach the VMs. The VMWare support checked on and told us it should be OK, but isn't working. Is there any guide or tip to make it work?
8 REPLIES 8
Thank you guys!
The customer re-checked all configs and now is working!
-Leo
LeoP1
Contributor
Hi Doug,
I'll check it with the customer and let you know...
Thanks for your usual help! Good to work with you guys at GTAC!
-Leo
Doug
Do you have the Vswitch (Security Tab) promiscuous mode enabled (Checked and Accept)? Also per Vswitch you need to select 4095(all) under the General Tab.
-Doug Hyde
Doug Hyde
Sr. Director, Technical Support / Extreme Networks
hsachse
New Contributor III
I think Doug is right. In most cases only the disabled promiscuous mode cause this failure.
You should follow the instructions in the "Enterasys Wireless Virtual Gateway 2110 Installation Guide". Maybe Doug could send you a download link.
