Extreme Management to Checkpoint Firewall Integrations
Matthew_Perry
New Contributor III
I was wondering if anyone was pulling user data from Extreme Management(NAC) into a Checkpoint appliance to Map IP to Users. Any if so how people were doing it. Also if there are any other integrations between the to systems?
12 REPLIES 12
Zdeněk_Pala
Hi.
the integration is ready and here is video how it works.
Enjoy.
Regards Zdeněk Pala
Zdeněk_Pala
Distributed IPS is working. Video is now available at GitHub. How-To configure it will follow soon.
Regards Zdeněk Pala
Antonio_Opromol
Contributor II
Hi, no one has tried this integration?
Antonio_Opromol
Contributor II
I've forget one screenshot of the snmp trap received
Antonio_Opromol
Contributor II
Hi all,
I'm trying to do a distributed IPS with Extreme Connect module (I'm using EMC version 7.1.1.9 and connect module version 3.02-3) and a Check Point R80.10 firewall.
I've defined the module as below screenshot
and on EMC I receive a snmp v1 trap as follow:
But is trap is not received by the Connect module specific for the Distributed IPS integration...
Has got someone a working scenario with Check Point and the Connect module?
Regards.
Antonio
