‎09-06-2021 02:44 PM
‎09-06-2021 04:12 PM
‎09-07-2021 05:46 AM
Hello
I would suggest that you configure a "untagged" port (Access port) in vlan 60 first and connect a laptop to this port to see if you receive a IP address.
If you do not receive a IP address, provision your laptop with a static IP in the 10.100.60.x range and see if you can ping the IP interface on the controller.
The problem might be with your DHCP server, or with the vlan not being tagged in your network infrastructure.
One thing to note is that the 3rd Party interface acts like a router, so for your DHCP server to be able to reach this subnet you will need to add some myloweslife route to get to the 10.100.60.x network, route to the wireless controller.
‎09-06-2021 04:10 PM
If there a way that we can forward Extreme Wireless Access Point log to any third party SIEM tools like FortiSIEM?
‎09-06-2021 03:45 PM
Ronald,
There is something missing in your question. Could you please elaborate a little bit?
Mig
