Identity Dashboard Engine (IDE) Authentication
Mohamad_Farezza
Hi Team, i have one question, In IDE if i want to use Radius access policy for MAC auth then i need to store the MAC in username format in the user set. My question, it is have the other method ? for example using wildcard just add MAC 6 digit only for IP Phone Avaya, it is possible? i have 1000 unit ip phone, can u suggest me the other method to implementation .
6 REPLIES 6
Mohamad_Farezza
Hi Shmulik, do you mean IDE can be combine radius auth and mac auth ? please share link for this method for my reference. thanks
Shmulik
Greetings Mohamad,
You can do MAC auh in two ways in IDE: as user auth or as MAC Auth. If you use the MAC Auth Policy method which is the more commonly used, then you can use wildcards for the MAC address in the local store. Take a look at the user guide.
Just reminder to all readers - we encourage migration from IDE to ExtremeControl.
Thanks!
Shmulik
