09-03-2014 09:47 AM
4 weeks ago
Integrating the C5210 with a billing system should be possible using a RADIUS server for authentication and accounting. The release notes and user guide provide the supported RADIUS attributes, which are usually enough to connect with most third-party billing platforms. Capturing a test RADIUS exchange with a packet capture can also help verify that the integration is working correctly.
a month ago
Good discussion. Whether it's ISP billing or utility billing, having accurate account and usage information available online makes management much easier for both providers and customers.
09-03-2014 09:53 AM
