09-29-2021 01:50 PM
Hi, I’m trying to monitor every device I have (switches, firewalls, machines, etc...) All of them were really easy to set a SNMP and start seeing some information.
When I began to add the access points to the monitoring tool, I couldn’t get the SNMP monitoring information. I tried to create a SNMP user but did no good.
These are the models:
- Wireless AP3705i Internal
- Wireless AP3935i-ROW Internal
- Wireless AP3825i-1 Internal
- Wireless AP3805i Internal
Didn’t found any subject or forum saying anything about it. I hope you can help me
Solved! Go to Solution.
09-29-2021 03:29 PM
Hi Pedro
These AP’s are managed via the controller, they don’t directly support SNMP themselves.
-Gareth
09-29-2021 04:12 PM
Hi Gareth
Thanks for your answer! So is it possible to monitor the controller and get information about the Access Points?
Hi Pedro
Yes this is possible, the controller supports snmpv1-snmpv3.
These articles in our KB should help.
https://extremeportal.force.com/ExtrArticleDetail?an=000083039
https://extremeportal.force.com/ExtrArticleDetail?an=000077378
-Gareth
09-29-2021 03:44 PM
Hi Gareth
09-29-2021 03:29 PM
Hi Pedro
-Gareth
