Tacacs Login Problem
Michel_Braga_Gu
Hello Folks...
I put myself on a big trouble, and I hope you guys can help to get me out of it.
Here in a company I'm working for, we have a Enterasys S8 Chassis with two fabric switches and two blades with normal switches.
We were trying to configure tacacs on it, we have done a lot of tests and we've got no success.
This is the config I used the first time we've tried:
set tacacs server 1 49
set tacacs command accounting enable
set tacacs command authorization enable
set tacacs enable
This one isn't work. So I removed.
Obs:
I had established a ssh connection to put this configuration, and keep this same ssh window connection to apply or remove this configuration any time I wanted, without any kind problem, and with another ssh windows we tried to connect with our tacacs users.
So, once I still have this ssh connection established, I was able to put another configuration to try get it working, then I put this one:
set tacacs enable
Exact the same, but at the end of it, I added:
set authentication login tacacs
And nothing, it haven't worked as well. So we decided to stop the tests for a while and try to make it work another day. Then we removed all the configuration above, but we forgot to remove the authentication line (set authentication login tacacs).
I read that this configuration turns the tacacs as my primary login method.
We've closed all of ssh connection windows, and since that moment I've logged out from my switch, I wasn't able to login on it anymore, neither with my tacacs user nor with my local user.
I don't know what to do.
Is there some way to login in this switch on a recovery mode, or boot it skipping my current configuration, so this way I would be able to change the configuration on my switch??
Please, someone, help me.
Sorry for the weak English and the Big Text.
15 REPLIES 15
Mike_D
Hello Michael,.
Another access method below. Previous clunky approach is still valid but its a poor plan b. Though a safe outage window is still required, the following steps make a far more attractive plan b. Simpler is almost always better.
Start with access to a valid backup config to minimize down time needed for reconfiguration.
to clear nvram,
* Pull one of the fabrics out of the system.
* Attach a console to the chassis and reset with the remaining fabric installed. Power pull is probably the only option unless things have improved on site.
*Almost immediately upon system diags/post messaging, begin tapping keys on the keyboard to interrupt boot and gain access to the boot menu (system image loader prompt) a bit like accessing the bios on a pc by interrupting boot process. The window to catch the interrupt is just a couple of seconds so it may take a couple of tries.
* Once at the system image loader prompt, a question mark will display a list of basic recovery commands, one of these will be clearnvram. execute this.
*Following reset you should be able to login with default credentials.
admin/ for superuser, public and private for snmp rw/ro.
*Plug in the second fabric module and the now cleaned-up chassis master should fix the second fabric. If you can call no-configuration a fixed switch.
*Reconfigure.
Mike
Mike_D
Hello Michael,
Do you have another fabric - say a spare fabric with no config or a fabric robbed from another switch? Can you suffer some level of downtime to recover this?
One stability mechanism used in the distributed environment is a forced firmware and configuration copy from the chassis master fabric (master handles snmp, external auth etc and is identified by a green mgmt LED on the front panel) to any new module booting in the chassis. With a 3rd fabric you could wipe out the configuration on each of the boogered up fabrics.
This suggestion requires a maintenance window - less than an hour of outage I'd expect - given a little planning. Another caveat - access to a valid backup of your switch configuration - minus tacacs - will be needed for recovery.
* Pull all fabrics and cards from the chassis.
* Insert the new fabric (#3) into the chassis. This fabric will become chassis master.
* Insert either of the fabrics with tacacs config - this will be erased.
* Pull out the spare fabric (#3) so the remaining fabric - now with erased config - becomes master. At this stage you should be able to attach to management console. Log in with the default user/pass of admin/ or the now copied fabric #3 creds.
*Apply the backup configuration to begin recovery. Copy and paste the configuration into console or configure snmp management access; use Netsite to transfer the config file. (or use ssh, ftp etc)
* Insert the remaining fabric so the new cleaned-up configuration will be inherited.
If you have a better method of isolating either misconfigured fabric card in order to force a blank or known good config copy (a spare chassis and fabric for example), there's no point in strictly following these steps. Just make sure you control the master and use it to overwrite the bad configs.
If shutting off access to the tacacs server doesn't do the trick, the configuration overwrite steps or something similar should get the job done.
Its clunky. Its lengthy. its drastic. But its a plan-b in case plan-a shows up looking still less attractive.
Regards
Mike
Dorian_Perry
Like Matthew suggested, if the switch can't communicate with the TACACS server, it may default to local credentials.
Have you tried disabling the TACACS server and attempting to login?
Matthew_Hum1
If you remove the uplink, and the switch gets no response back from the TACACS server I think it defaults to local accounts.
Michel_Braga_Gu
I think the switch have the snmp configuration on it's default.
Do you know the name of the default read-write community?
Since now I appreciate your help.
