Tacacs Login Problem
‎01-13-2016 07:59 PM
Hello Folks...
I put myself on a big trouble, and I hope you guys can help to get me out of it.
Here in a company I'm working for, we have a Enterasys S8 Chassis with two fabric switches and two blades with normal switches.
We were trying to configure tacacs on it, we have done a lot of tests and we've got no success.
This is the config I used the first time we've tried:
set tacacs server 1 49
set tacacs command accounting enable
set tacacs command authorization enable
set tacacs enable
This one isn't work. So I removed.
Obs:
set tacacs enable
Exact the same, but at the end of it, I added:
set authentication login tacacs
And nothing, it haven't worked as well. So we decided to stop the tests for a while and try to make it work another day. Then we removed all the configuration above, but we forgot to remove the authentication line (set authentication login tacacs).
I read that this configuration turns the tacacs as my primary login method.
We've closed all of ssh connection windows, and since that moment I've logged out from my switch, I wasn't able to login on it anymore, neither with my tacacs user nor with my local user.
I don't know what to do.
Is there some way to login in this switch on a recovery mode, or boot it skipping my current configuration, so this way I would be able to change the configuration on my switch??
Please, someone, help me.
Sorry for the weak English and the Big Text.
set tacacs server 1
set tacacs enable
Obs:
I had established a ssh connection to put this configuration, and keep this same ssh window connection to apply or remove this configuration any time I wanted, without any kind problem, and with another ssh windows we tried to connect with our tacacs users.So, once I still have this ssh connection established, I was able to put another configuration to try get it working, then I put this one:
set tacacs server 1
set tacacs enable
15 REPLIES 15
‎01-14-2016 11:15 PM
Hi Michel,
Are you using NetSight to manage this switch?
