Getting ready to enable Auto Tx Power Ctrl (ATPC) for AP3605. What value do I need for Auto Tx Power Ctrl Adjust? Is this the range up or down it can go or does the min max values set that? Also how does it determine when it needs to adjust power? Any info is appreciated.
A typical setting would be to set the Max to the highest setting in the config and Min to the lowest setting (in dBm). The system will automatically try and adjust in that range. It does so by sending packets in the air with a name defined in the RF Domain field. Each access point hears that packet and can determine how to automatically adjust the transmit power of an ap.
Doug Hyde Sr. Director, Technical Support / Extreme Networks
