Wireless clients roaming between APs
Ryan_Relihan
What settings can I tweak to make sure wireless clients roam to closer access points in different parts of a building? We are using a C4110 controller with 3605 and 3610 APs.
5 REPLIES 5
Simon_Vosper
New Contributor III
Like the guys before have said, you can modify roaming aggressiveness on the client or modify data rates so that the wireless network disappears at a certain distance from the AP, but the key thing to remember is that the decision to roam is taken solely by the client device itself. The decision is based on a variety of factors that could include among other things signal strength, SNR and retry rate. The roaming triggers and deciding factors vary among client device vendors and is included in the client device drivers. Making sure that device drivers are up to date can often yield better roaming algorithms on the device, so I always start there.
Jonathan_Galdam
where can see this in WM3600?
Vibhor
In wireless NIC, under properties >advanced, there is an option : Roaming Aggressiveness. You can tweak those setting to experience the change.
Cibulka__Leandr
New Contributor II
That is correct > AP > Radio> Advanced : Set the Min.Basic Rate to 1 or 2 Mbps.
