Added 3825e to C25 Controller, won't go active?
Don_Tuleja
I just opened a new site. Added the appropriate licenses to my C25 controller, and installed 6 new AP's. I can get the controller to see them, but I can't get them to go active. Configs appear good and complete, but the radios stay off, and the topology box shows "Inactive".
I do have the radios enabled on the radio pages.
What could I be missing? I just copied the configs from my other AP's to the new ones.
14 REPLIES 14
This is an existing environment. The VNS are showing assigned to the AP's.
Don_Tuleja
On the AP Properties tab? Yes. It's set to United States.
Jeremy_Gibbs
Contributor
Is your country set?
Don_Tuleja
Thanks,
Yeah, did that too. 
Pic here: http://i.imgur.com/Ic1dPvV.png
Jeremy_Gibbs
Contributor
Go to the AP properties and click on the "Professional Install" button and select the antennas you are using. Then make sure Radio 1 and Radio 2 are set to "on".
