AP radio active status does not update on 2nd controller after taken out of load group of 1st controller
Christopher_Tay
Contributor
We have 2 C5210s in high availability pair running version 10.51.04. When we remove a VNS from the load groups on the controller to which they are assigned the radios remain checked and greyed out on the VNS WLAN screen of the other controller.
Synchronize is enabled.
1 ACCEPTED SOLUTION
Umut_Aydin
Hi Chris,
sorry for the misunderstanding..I got it now.
I need to update both of my EWC to the newest code but tested it with the 10.51.03 and it's working for me.
If I remove the VNS from the load group it will get removed also on the WLAN Service screen on that AP'S as weel. It takes some seconds but it's working.
It seems it's broken in 10.51.04.
Could you please open a case and GTAC can work on this.
Thank you.
Regards
Umut
7 REPLIES 7
Umut_Aydin
Hi Chris,
I assume that you remove the VNS only under the WLAN Assignments but
the AP was still selected here under the AP Assigments within the Site..or?
Uncheck it and the radio should be available under the VNS WLAN Screen again.
https://
Regards
Umut
Christopher_Tay
Contributor
Hi Umut,
What do you mean by "Still had AP in the SIte ..in the AP assignment"?
Umut_Aydin
Hi Chris,
I made a quick test and could also see this.
But I assume ..like I had during my test.. that you still had the AP in the Site ..in the AP assignment..
If you remove them here the options are available again.
Regards
Umut Aydin
