AP3865e External SSID Problems
Shkelqim_Kajtaz
I have installed AP3865e External, i can see all the SSID-s on mobile phone and in some llaptops but in some llaptops i cannot see the SSID. I have and older Wireless AP3660 External on this AP works fine both mobile and all llaptops. Can anyone help me with this problem.
Here is my settings of my AP radio 1 and radio 2
Radio 1
Radio 1 Advanced Settings
7c61e5381ea442f8900a7965aea9b929_RackMultipart20170323-71695-18fm5kr-1_adv_inline.jpg
Radio 2
Radio 2 Advanced Settings
7c61e5381ea442f8900a7965aea9b929_RackMultipart20170323-103958-7efx8c-2_adv_inline.jpg
6 REPLIES 6
Zdeněk_Pala
I would guess the issue is with the wireless nic or drivers. Check if the behavior is the same if you change channels. Some clients does not support all frequencies (like DFS channels).
Regards Zdeněk Pala
Rajesh_Jeevendr
Hi Shkelqim
Thank you for the post.
Laptops that couldn't see the SSID, could you check if they are configured for G only or A only mode.
Is there a difference in wireless NIC driver among the working and non-working laptop.
Regards
Rajesh J
