Hello Yury, thanks for that quick response.
How would I know which EAP that the AP/phone is using? It seems that regardless of what I chose on the phone, the result is always "connection failed". That message doesn't help much. These phones run a Linux kernel underneath. So perhaps I can hook up a USB cable and do some debugging or verbose logging.
The phones do not seem to support OKC or 802.11r.
I think I lied about the PSK thing. I must have remembered that wrong. Cisco said to avoid TKIP, but that PSK would be acceptable if WPA2/aes was not an option. Here is
that article.
This is a real apples to oranges comparison. There is really no reason to believe I will have any of the same old problems with these phones and Extreme AP's with completely different settings.
Also - I am not crazy about these Cisco 79xx phones. They cost a small fortune. They are not sealed well. And they cannot be easily cleaned in a clinical environment. I would like to pursue some other options. But they would have to be supported by middle-ware software that we use to push alarms and alerts to the phone for our nursing staff. The Ascom phones look really appearing for healthcare, because they are sealed so well. But if anyone wants to suggest a model or brand, you are welcome to.
EDIT: I meant to add that I have a non-medical floor with 5 Cisco access points. This might be a good floor to switch out with Extreme AP's as they do not carry the IP phones on this floor. That would allow me to walk around and do some testing without causing any problems for my nurses.
