ā05-07-2020 06:29 AM
how to check management interface ip in wireless controller
ā05-08-2020 01:25 PM
Hi Ompal,
What is the controller? Is it V2110 or some physical appliance? Iād recommend to use GUI to go into VNS or Controller menu, then Topologies. With V2110 for example, you will most likely have a āphysicalā type topology with some IP address and AP registration + management enabled.
Under CLI you can login and type ātopologyā, then āshowā.
Hope that helps,
Tomasz
