Yes
When select the interface for mirror the physical link going down. The interface has plugged directly on server.
If I mark speed (100Mbits full-duplex). the interface is going up (SELECT DIRECTLY on server)
If i select NONE on "traffic mirror l2 port" the port is going up (1000 FD)
Default traffic mirror is BOTH..
This occurs on version 9.21.04. On others versions 9.21.03 this funcionality is allright
Can you explain more on what you mean, going down? Are the ports disconnected? The physical ports can either be used as a mirror or to egress topology traffic, not both.
Doug Hyde Sr. Director, Technical Support / Extreme Networks
