Remote Port Required
Terren_Crider
New Contributor II
I'm reconfiguring a wireless network and have run into an issue. Currently the network is set up as a /16 subnet and I'm reducing it to a /22. I changed the gateway device's mask to /22, but when I try to change the controller's mask it tells me that "The Remote Port is Required". What am I missing here?
4a3f142b7ffa4b3c9c4a03f5727dea18_RackMultipart20180124-71623-1hk88k3-wireless_prob_inline.png
3 REPLIES 3
Terren_Crider
New Contributor II
Well... It appears that the problem was the Synchronize checkbox. I had to uncheck it since this topology does not exist on my other controller.
Reference: https://gtacknowledge.extremenetworks.com/articles/Solution/ExtremeWireless-Error-when-saving-a-port...
Doug Hyde
Director, Technical Support / Extreme Networks
That's funny. I had this same issue. But when I saw you post this error message I was racking my brain about what I did to get that message.
