07-14-2021 07:25 AM
Hi everyone,
I´ve some strange situation with Android Smartphones in our Aerohive/Extreme Network (Mix of AP250 and 305C) environment.
The Android devices itself get´s an valid IP and authenticated to the Wifi but shows the information “maybe don´t have internet connection”.
Actual Workaround: Ping the device. The first 2 packages are lost, but than the device replies and shows connected.
I´ve started this discussion last year, but with Covid-19 the situation stuck.
I´ve also found that we are not the only one with this situation.
I can confirm that DNS port 53 and 853 is open for this dedicated Wifi VLAN on our firewall.
I´ve added the DNS ports for the native VLAN of the APs to this internal DNS server, now.
Does anyone has an idea, if this won´t help, how we could troubleshoot this?
Thankful for every idea!
Solved! Go to Solution.
09-07-2022 02:06 AM
I want to send an update about this topic.
We found the root cause for our problem, but I´m unsure how to solve it.
The ARP-cache on our firewall which is also the Gateway for our Guest Network seems to get some wrong information from the Aerohive environment.
The Guest Wifi has a short Lease time on DHCP side (5min, increased to 15min now).
The client itself gets the correct IP from DHCP Server (same VLAN/subnet, Windows Server), but the Firewall still get´s the wrong information after a arp-cache clear.
We deleted the "wrong" client in the IQ Management and cleared the ARP-cache once again and the problem was solved for this device.
We found an option in the "Management Options" called "disable Proxy-ARP":
Would it make sense to activate this option in a Wifi environment?
Arp-Caches are written on the Gateway and Switch devices.
08-02-2021 05:44 AM
Hi. No we don´t using ipv6. I had this situation with the last firmware updates.
Which one are you using that seems to work?
I´ve opened a ticket over our partner. We will see.
07-31-2021 09:39 PM
Do you have IPV6 in your environment I recently had basically this same issue with Android. I fixed it by downgrading firmware version.
07-26-2021 08:13 AM
we get the ticket response that we have a PWP contract (Partner Work Plus).
I´m opening a ticket at our local partner.
07-22-2021 07:30 AM
Hi. I´ve opened a ticket.
Thank you for the response.
07-15-2021 02:30 PM
Hi there, I ran this past our XIQ technicians and they requested we open a case for this issue. If you could go to our portal at extremeportal.force.com and open a technical support case, we can help you from there.
