DHCP vs Static IP Addressing Issue (Aerohive AP650 / Extreme AP510C)
‎04-10-2023 12:13 AM
I have Aerohive AP650 / Extreme AP510C access points deployed with the 10.5.4.0 firmware. I have configured an "isolated" VLAN with the L3 switch acting as the gateway.
If I enable DHCP on the "isolated" VLAN, which the customer does not want, the wireless clients associate and have "Internet only" connectivity via the L3 switch.
If I utilise static IP addressing using exactly the same values as the DHCP scope the wireless client associates but cannot PING the default gateway. If I take the same Windows 10 laptop and connect it to a switch port configured for the "isolated" VLAN it can PING the default gateway and has "Internet only" access. Therefore, the issue appears to be the Extreme wireless network.
I cannot see an "Enforce DHCP" option (or equivalent) in the SSID settings or Network Policy Management Options but I can see an "Enable DHCP Shield" option. Could this be causing the issue?
