I have 2 ssid broadcasted from same wireless network gives different speed in 5G
saidaikrishna
New Contributor III
Checked the SSID configuration- > similar configuration
similar speed rate setting  but different in connection speed due to it the users those who are connected to DL SSID facing issue when they move away from access point.
5 REPLIES 5
mvegmond
New Contributor II
Hi, can you have a look if the DL network is using auto-WPA/WPA2? (or just WPA?)
chrs
You mean to check on the client machine..  It is Auto
Below is our dashboard configuration :
Please change encryption to AES and try again
chrs
Tomasz
Valued Contributor II
Are users connected to TPIND-DL only get 54 Mbps of datarate at most, or can it get greater than this? Are both networks on 5 GHz?
Kind regards,
Tomasz
