I have 2 ssid broadcasted from same wireless network gives different speed in 5G
‎12-10-2021 06:02 AM
Checked the SSID configuration- > similar configuration
similar speed rate setting but different in connection speed due to it the users those who are connected to DL SSID facing issue when they move away from access point.
5 REPLIES 5
‎12-15-2021 02:06 AM
Hi, can you have a look if the DL network is using auto-WPA/WPA2? (or just WPA?)
chrs
chrs
‎12-15-2021 02:36 AM
You mean to check on the client machine.. It is Auto
Below is our dashboard configuration :
‎12-15-2021 02:39 AM
Please change encryption to AES and try again
chrs
chrs
‎12-10-2021 03:26 PM
Are users connected to TPIND-DL only get 54 Mbps of datarate at most, or can it get greater than this? Are both networks on 5 GHz?
Kind regards,
Tomasz
