01-20-2026 10:19 AM
We recently made a bunch of tweaks to our Wifi Profiles in XiQ. After those changes, the Sonos Portal that we used for A/V in one of our Gyms no longer works. The Sonos sees multiple SSIDs now (all the same SSID) but won't connect to any of them.
Has anyone had a similar experience or suggestions?
Solved! Go to Solution.
01-27-2026 09:57 AM
We got it working.
We created a separate SSID for 2.4 GHz with WPA2 only. That was enough.
Thanks to all of you!
01-22-2026 06:07 AM
It may be based on the generation of the speakers you have. I have a system that is about 8 years old, and I ended up setting up a specific SSID for just those... Take a look at... https://support.sonos.com/en-us/article/supported-wifi-modes-and-security-standards-for-sonos-produc...
