3 weeks ago
We’ve been noticing recurring black dots in our DHCP logs, which seem to align with user reports of network drop-offs. Each time, the logs show “DHCP did not occur.” What’s puzzling is that these users are stationary no movement or device relocation yet it looks like a roaming event across access points (APs) occurs, followed by several minutes of network loss. We’re trying to understand what these black dots indicate in DHCP terms and whether they signal AP roaming, DHCP lease renewal issues, or something else causing these intermittent connectivity disruptions. Any insights would be appreciated.
14 hours ago
I am having the same issue not sure when it started. The black dots coincide with unknown error messages in the "Client Monitor and Diagnosis" tool. Also there was a document on the Extreme community portal Monday Nov. 17th regarding this issue but it has since been removed. See screen shots attached.
13 hours ago
Forgot to say when you see a black dot with "DHCP did not occur" you will see this in the "Client monitor and diagnosis"
2 weeks ago
Those black dots usually mean the AP couldn’t complete a DHCP exchange. It happens when the client drops briefly during reauthentication or channel change. Check if DHCP lease timers are too short and watch for 802.1X reauth events that interrupt renewals.
The 10.8.4.0 firmware also had a bug causing this update to 10.8.4.1 or later.
Extreme Networks Troubleshooting DHCP Relay/Client Issues
How DHCP Works
a week ago
I said that 10.8.4.0 was a sloppy firmwaare: https://community.extremenetworks.com/t5/extremewireless-iqe/another-broken-firmware-update-10-8-4-0... I wasnt just flapping my gums! totally messed up my AP's and that wasnt even this DHCP bug! seriously dont they test their firmware in a lab before dumping it onto us. Customers are NOT their **** beta testers!
