AP7522 Wing Express interface ge1 DOWN
Ronald_Groenewe
I've made a change via the GUI and it has disabled the GE1 by default. So now I cannot access the interface anymore. As the wireless networks are in a different VLAN I'm unable to check the settings in the web interface.
Is there a way to enable interface GE1 again via the CLI?
7 REPLIES 7
Ondrej_Lepa
Hello Ronald,
please be aware there is a recognized bug SPR-31767 related to LAN settings done via GUI.
When you do changes to LAN port, port goes disabled for no reason. If you do not notice this and click apply, GE1 is disabled.
See another thread we sorted this out and let me know if this is same situation or your port went down for other reason.
https://community.extremenetworks.com/extreme/topics/wing-express-lan-settings-disable-by-deaultIf you have any more question just ping us back.
Regards,
Ondrej
Ronald_Groenewe
This Ap is on 5.8.6.0-011R so i guess there's only one option... factory default.
Wei_Liang_Loh
May I know what version is your AP7522E?
If is 5.8.0 and above, it's advise that you connect it using console and factory default it.
Below are username and password for factory default:
Username:reset
Password:FactoryDefault
