Captive Portal Options in WiNG 5.9.1
Saravanamurthy_
Contributor
In RFS 4000 OS Version is WiNG 5.9.1. Actually i want use captive portal. I seen Captive Portal Type 1. No Authentication Required. 2. Radius Authentication. 3. Registration. 4. Email Access. 5. Mobile Access. 6. Other Access. In these Six, which are used with out NAC Software? Explain.
13 REPLIES 13
Saravanamurthy_
Contributor
My problem is Guest access the ssid, that time mail will send to the authenticate person, after that person approve the access through mail to the guest.
What are the requirements need to solve this problem?
Is there any special configuration to work with AP VC configuration (Advanced GUI interface)?
RGRDs
Michal
Tomasz
Valued Contributor II
Hi Saravanamurthy,
If you are looking for a sponsored authentication (guest reaches SSID, puts his e-mail, then a message goes to a 'sponsor' and that person approves the guest), on WiNG it can be run with ExtremeGuest solution or with Extreme Access Control.
Hope that helps,
Tomasz
