Captive portal options in WiNG v5.9
Niyas
New Contributor III
I have VX9000 controller and extreme AP 7502, I have created 4 SSIDs(Students, Admin, Teachers, Guest)in the controller. I need to access the internet through created SSIDs.what are the steps needed to access the internet through created SSIDs?
Thanks
Niyas P
27 REPLIES 27
Nuno_Rocha
Hi Niyas,
Yes it's exactly that, all data traffic with be delivered to your network at the AP.
Niyas
New Contributor III
Hi Nuno,
VLAN 14 is our management VLAN, you mean no need of data VLAN in Controller?
Thank you
Nuno_Rocha
Hi Nyas,
on the controller you will only need the vlan 14, all the data traffic will exit out of the AP to your network either as bridge, your VoIP VLan, or with NAT for your other vlans if you so wish it.
Niyas
New Contributor III
I have one doubt, my controller IP is 10.4.4.41/22 with VLAN 14 and my data VLAN is 18.controller is running on VMware platform with only one GE port.so how to configure ge1 port of controller?
Please find the below settings, this is correct or not
Native VLAN 14 with IP:10.4.4.41/22
Mode : Trunk
Allowed VLAN: 18,20,22,24,33,34
Thank you
Niyas P
Niyas
New Contributor III
Hi Nuno,
Please find the below screenshot, this is correct or not? my voice VLAN is 17, I need to access voice VLAN 17 through AP FE1 port, so need to allow through controller also?
ce8b87b344844eae955a04864a02da6a_RackMultipart20180807-110804-vu1a4t-New_GE1_inline.png
Thanks
Niyas
