Channel Invalid For Radio and Low Signal for AP 7562
izzeterol
We have 7562 in our system and for radio2 i see this message “STATE                : Off [channel invalid for radio]”. Also despite 10.0 dbi 2.4 antenna and 5.9 dbi 5 GHZ antenna the access points are performing bad signal distribition. When i walk away 10 meters from AP, we are losing the signal.
1 ACCEPTED SOLUTION
Christopher_Fra
Hello Izzeterol,
     Please answer the following:
What Country Code is the AP configured for via RF-Domain?
What channel is radio 2 mapped to?
What version of Wing firmware is the AP currently running?
If using external antenna’s, you need to add the gain for each radio via AP Profile/Interfaces/Radio/Antenna Gain
What type of deployment is this? (Virtual Controller, Wireless Controller, Stand-alone)
From the AP CLI, you can use the following commands from the privilege prompt (enable):
enable [enter]
show wireless regulatory ?
    channel-info  Channel information
    country-code  Country code to name info
    device-type   Device type
Based on the Country and radio 2 being Placement OUTDOOR, will dictate what channels can be used.
5 REPLIES 5
Tomasz
Valued Contributor II
Hi Tuan,
Could you please provide us with more input according to Christopher’s post then, please? We can try to help then. 🙂
Kind regards,
Tomasz
Tuan_Nguyen1
Hi @izzeterol I am having the same problem as yours. Can you share your fix for me?
izzeterol
Hi ;
Thank you for your interest, i solved this problem with a related topic.
Christopher_Fra
Hello Izzeterol,
enable [enter]
