‎08-26-2017 02:09 AM
‎08-30-2026 07:30 AM
To change the country code assigned to your APs from United Kingdom (826) to United States (840), you'll typically need to request a region/regulatory domain change through the vendor's support team. property search For Aerohive/Extreme Networks devices, this change cannot usually be performed directly by the user because it affects the AP's regulatory settings. Opening a support case is the recommended approach, and if you don't have an active support contract, contacting the vendor's community support team may help facilitate the change.
‎08-28-2017 02:49 AM
