‎03-16-2018 03:47 AM
Solved! Go to Solution.
Monday - last edited Monday
The browsing experience on Moviebox APK looks fairly simple. The Moviebox movie collection makes it easier to explore different titles.
‎04-08-2026 02:37 PM
That’s a solid explanation and pretty much aligns with what I’ve seen in similar setups. Relying only on Application Policy can be limiting, especially with HTTPS and how modern apps distribute traffic across multiple domains.
Using firewall rules to block key domains and applying them at the WLAN or role level is definitely a more reliable approach. For stricter control, combining that with an external firewall or filtering gateway makes a big difference, especially when dealing with mobile apps and encrypted traffic.
I’ve also come across similar discussions while researching app behavior and traffic handling on platforms like manoknapulaapp, where it’s clear how diverse backend connections can bypass simple filtering methods.
Overall, your approach makes sense for achieving more consistent blocking across devices.
‎03-22-2018 06:52 AM
‎07-03-2019 11:35 PM
‎03-16-2018 07:32 AM
‎03-16-2018 06:13 AM
