L2TP Tunnel between RF-Domain and DMZ NX-5500-100R0-WR cluster
msalaque
Hello All
I am doing a solutions where Corp SSID will be local bridge at each site ( RF-DOMAIN) with Centralized cluster (NX-9600).
We also need to have guest SSID at each site with traffic tunneled to DMZ cluster 2 x NX-5500.
I found two documents
  1. https://documentation.extremenetworks.com/extremewireless/WING_5X_TUNNELING_REMOTE_TRAFFIC_HTG_TME-0...
  2. https://extremenetworks2com.sharepoint.com/sites/kcs/External/000014264/WING5X_How_To_Tunneling_Remo...
I tried to test those configuration in my lab using VX900 (v7.4.1) but unable to find all the options .
could anyone let me know if those are updated documents or help me finding right documents?
Moreover , Am I digging right directions?
1 ACCEPTED SOLUTION
Ovais_Qayyum
You won't be able to test the L2TPv3 configuration on a VX9000 controller because tunneling is not supported on it due to a lack of data plane. As for your use case, you have two tunneling options:
1- Native MiNT tunneling: it’s less secure, easier to config, does not support fast failover.
2- L2TPv3 tunneling: it’s more secure, supports fast failover, and quite flexible to configure.
The guide you have is correct, just use it with physical appliances and you should be able to complete the lab test.
Regards,
Ovais
6 REPLIES 6
SamPirok
Community Manager
Hello, I am looking in to this for you and I will update you as soon as I know more.
msalaque
Anyone could provide me some guide on it please ? It will be highly appreciated.
